28.1.0 Preview: 3D Window Glitch
Eduardo Rolon
With any "3D Style" that has "Shadows" on"
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
5 REPLIES 5
runxel
Hero
Rather looks like you have two walls in the same position:
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Nope. Single wall.
If you don't have shadows on there is no glitch.
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
Update,
Looks like moving the Sun in the 3D Window setting resets the shadow and the glitch is removed.
The original file still keeps the glitch.
AC28 US/INT -> AC08
another Moderator
Huh, interesting. So it happens only in the "shadowed" side?
Mh, I've seen similar issues with wonky graphics drivers, but you're on Mac, so that shouldn't be the problem either. Maybe send the file to the support for them to check it? 😕
Not necessarily on the shadowed side.
File sent just in case.
AC28 US/INT -> AC08
another Moderator
