Installation & update
All project previews gone after Sequoia update
Rick Thompson
Anyone else noticed this after updating to Sequoia???  This sucks big time for me.  I have/had project previews set for hundreds of files that I routinely open.  This is important for my work flow.  I am on AC26, so I can't expect Graphisoft to fix it, if that is needed.  I have not tried re-indexing the computer, but maybe that's a fix???  I tried to reset the image, but no changed.  The image is still set in the Project Preview window.
Suggestions welcome.. thanks
Operating system used: Mac Apple Silicon Sequoia
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
4 REPLIES 4
I’m not sure if it is linked to the same issue but you used to be able to quick preview an Archicad file (single click and spacebar) and it would bring information up about the file including the Archicad version number which was useful when running several versions of Archicad. This information is no longer available in quick view. I suspect the project preview may be linked to this.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
This may also shed some light on it.
https://discussions.apple.com/thread/255762577?sortBy=rank
Lee Hankins
Rick Thompson
Thanks, the space bar just brings up the standard AC stock image that was there before setting the custom one. Having the rendering (in my case) set for that is really helpful since I have several hundred plans and can't remember which plan is a particular plan number, so it's a valuable short cut to make sure I am opening what I think I am.  I spent a long time getting all those set up properly.
Rick Thompson
Mac Sonoma AC 26
That's the same issue for sure.  Glad to know it seems wide spread, so maybe apple will fix it sooner than later.  Does seem like an indexing issue.  Yeah, people with photos identified by the thumbnails are hurting.  Thanks
Rick Thompson
Mac Sonoma AC 26
Setup info provided by author
