Installation & update
ArchiCAD won't open any files, goes inactive
Caio S
hi everyone, i'm relativly new to ArchiCAD but now i'm experiencing an issue where i can't open any files. The start menu opens up fine but as soon as i press "new", "open" or try to open a recent poroject it doesnt do anything. The cursor starts loading and it takes around ten to twenty minutes until the file starts opening. In the taskmanager the process "Archicad starter" goes inactive.
My setup: HP OMEN Lapton with 12th Gen Intel(R) Core(TM) i5-12500H  /  NVIDIA Geforce 3050 LaptopGPU, Operating System is Windows 11
Things I've already tried:
Reinstalled ArchiCAD, Reset PC entirely, reset and updated all graphic and processor drivers, checked firewall (ArchCAD is not restriced or something), deactived firewall to be sure (still same issue), booted in safe mode and clean boot (still same issue).
I'm running out of ideas and would be grateful if somebody either is experiencing the same issue or may have an idea what else could cause that.
Any help is welcome:)
Botonis
Mentor
Which Archicad version are you using?
What kind of license?
Are you using the 3050 GPU or the internal one?
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
vistasp
Also, how much RAM does your machine have, @Caio S ?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Can you also check this on another machine? That way we can figure out if it is the file (if it is an issue on both machines) or Archicad on your machine (if it opens fine on the other machine).
Setup info provided by author
