2025-02-02
06:38 PM
2025-02-11
03:19 PM
Gordana Radonic
Hello everyone,
I'm experiencing a long delay in the HOME SCREEN menu when opening Archicad 28 and when deleting recent projects.
The same delay also occurs when I open the HOME SCREEN while working on a project.
Is anyone else facing these issues?
Archicad 28.0.2 Int.
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz 3.70 GHz
32.0 GB (31.7 GB usable)
NVIDIA RTX A4000
Windows 11 Pro
Takis Apostolides
Solved! Go to Solution.
2025-02-12 04:05 AM
The problem with slow start screen has been around for quite a while for me since AC24, especially after a huge module publish, most likely due to the recent open files list. To clear it quickly I always close all AC and delete the "Recent Documents (Project).prf" and "Recent Documents (Symbol).prf" under:
C:\Users\user_name\AppData\Roaming\Graphisoft\ARCHICAD 26.0.0 XXX R1\
or
~/Library/Preferences/GRAPHISOFT/AC 26.0.0 XXX v1
and it should be instantly quick afterward. I guess it still applies to AC28
BIM Manager
DKO Architecture - HCMC
2025-06-11 02:02 PM
Hi all,
FYI: fixed this issue for 28.3 and 29. Happy to bring some good news.
2025-02-02 11:29 PM
Yes i am having the same issue
2025-02-03 02:24 AM
Still not liking that window and I agree it is extremely slow.
IMO after using AC for 20+ years I don't need to see sample projects…
another Moderator
2025-02-10 09:33 AM
Hi all,
We do know of an issue that is causing performance problems with web-based content across remote desktop connections.
Can you confirm if this is the case here or is the slowness present on your local machine?
Any pattern could help us to address this issue.
Thanks in advance,
Zoltán V.
2025-02-10 09:50 AM
It is on my local machine.
2025-02-10 02:47 PM
Unacceptably slow on launch in local machine connected directly to router with average dl speed of 500Mbs.
The pattern is simple:
I really Hate-HATE this screen and I hate it more every time I need to launch 27…
another Moderator
2025-02-10 03:02 PM
@Eduardo Rolon the "27" was just a typo hopefully, since there is no home-screen in AC27 🙂
I am really interested in getting to the bottom of this issue, since we do not experience this kind of problems and nor did we receive similar reports through other channels. So any input here is valuable to me: screen recording of the problem, display specifications, storage type info (hdd or ssd), recent list content, anything.
Feel free to reach out to me directly in direct message or email, so we can work on this together.
2025-02-10 05:28 PM - edited 2025-02-10 05:29 PM
No typo.
The startup screen in 27 is much better than 28. I can launch 27 and select a previous file in under 8 seconds.
AC 28 takes 45.
So every time I open AC27 I am reminded of the slowness of 28.
IIRC I reported this during the Beta and at a minimum I posted this 4 months ago.
https://community.graphisoft.com/t5/Wishlist/Disabling-AC28-s-New-Home-Screen/idi-p/633856
and this is August 2024
https://community.graphisoft.com/t5/Open-discussions/Anybody-liking-the-new-Home-Screen/td-p/620716
another Moderator
2025-02-11 02:58 AM
Archicad (28 in particular) certainly likes to be installed on the main SSD drive.
I had it installed on a second HDD as I was low on space, and it was much slower.
Re-installed on SSD and much faster.
But I have noticed it seems slows down over time - I am sure it is not just my imagination.
I think it is an accumulation of preference files and recent files and sometimes auto-save files in our user profiles that are not being cleared automatically.
I don't use 28 as my main Archicad, so have not really investigated anything.
Certainly in 25, 26 & 27, the recent list of files seems to slow the start screen.
I always try to clear the old ones when I know I don't need them any more.
I would happily go back to just having 8 or 12 most recent files as it was pre start screen.
2025-02-11 12:59 PM
Every time I click on the recent list to remove old items it beachballs between 30-45 seconds. So clearing up the oldest 10 items takes between 5 to 10 minutes.
If I switch to another Tab I have to wait to switch back it doesn't come to the front since it is beach balling in the background.
another Moderator
