Cosmetic glitches in ARCHICAD on macOS 10.13 High Sierra
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Affected versions: ARCHICAD 21 and older | Severity: fixed
Issue
In List Type Dialog Views (like in Settings Dialogs, Favorites lists, Object lists, etc.), some icons and/or texts might be missing and/or the tabulation might be missing. See some examples below:
Solution
These issues should be fixed in the latest Update for ARCHICAD 21 (build 5021) and 20 (build 7001). Make sure you have the latest updates installed.
