Issues with dropdown menu after the last hotfix
HDES
I'm running a MacBook M3 OS Sequoia 15.6.1 and Archicad 28.3.1. I've been having an issue since downloading the last hotfix, where the dropdown menus won't go away after I use them. For example, I opened the file menu, and now I have the grey rectangle in the top left corner of my screen that I can't close. Is anyone else having this problem? Is there a solution? File size doesn't seem to matter. I've rebooted the computer several times, and it continues to happen.
5 REPLIES 5
It appears to be a Mac issue when you have an external monitor connected.
https://community.graphisoft.com/t5/Installation-update/ArchiCAD-29-Bug-empty-window-over-working-wi...
Is this your situation as well?
Do you have an external monitor?
Be sure to report this to your local support.
The more people that report this, the more likely it will be looked at.
Eduardo Rolon
Have had the issue without a Monitor connected.
Looks like it is a macOS issue only.
See here:
https://community.graphisoft.com/t5/Installation-update/Drop-Down-Menu-UI/m-p/686494#M39074
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Aaron Bourgoin
Pace Barry, I'm adding my name ot the list who experience this issue. Please fix it.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
Space_Agency
Same. On mac. No monitor connected.
Archicad V26 /V27 USA
MacBook Pro M1 Max
ram 64GB
Mac OS Sonoma 14.2.1
Also, this just started after the latest hotfix. Very disruptive.
MacBook Pro M1 Max
ram 64GB
