Primary address is missing after configuration of BIMcloud / BIM Server on macOS 10.13 or newer
Noemi Balogh
Affected version(s): BIMcloud 21, BIM Server 21 | Severity: workaround applicable | ID: #229603
Issue
During installation at the end of the configuration process of your BIMcloud 21 / BIM Server 21 you may get the following warning message:
Workaround
You can prevent this issue by logging out in the end of the configuration instead of proceeding with the Masteradmin user.
If you have already chosen to “Continue as Masteradmin”, click on “Set primary address” and choose your current settings to “Use”.
