2025-03-17 10:38 AM
Please help !
By chance I have pressed some keys and my 3D looks wierd
as if something is cutting it off.
I need to desactivate it but can't find where. Would like to know also what shortcut did I presss to activate this function.
Thank you for your help.
Solved! Go to Solution.
2025-03-17 12:49 PM
This might also be an object placed far away from the project origin.
Try to go to the floorplans zoom to fit with all the layers turned on to check.
2025-03-18 08:13 AM - edited 2025-03-18 08:14 AM
Problem solved !
The issue occurred after I pressed some keys on my keyboard, causing two walls to intersect at an infinite point. Removing that solved my 3d.
2025-03-17
11:13 AM
- last edited
a month ago
From what I saw, it can either be a clipping plane issue or a OpenGL issue.
Maybe you can take a look here
https://community.graphisoft.com/t5/Libraries-objects/Problem-Unwanted-cutting-plane-appears-2m-in-f...
Possible solutions:
- switch to axonometric and back to perspective, see if the issue persists?
- rebuild the file (it may become corrupted)
- check the 3D style option settings - maybe it can help?
edit:
- it also may occur if your model is placed too far away from the origin - maybe check that as well
2025-03-17 12:49 PM
2025-03-18 02:20 AM
Given the artifacts, I would assume it is a Project Origin issue.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Problem solved !
2025-03-18 09:25 AM
Nice to see problem solved.
