Installation & update
There is a bug in Archicad 28 version 3060 where changing quick select with the spacebar is not poss
Lee KiSeong
In Archicad 28 version 3060, the function to temporarily toggle Quick Select with the spacebar is not working, while using Shift + Spacebar does work. Is there a way to adjust the settings to fix this?
PS 1.
I've already tried resetting the settings.
PS 2.
Rolling back to version 3000 restored normal functionality.
Operating system used: Mac Apple Silicon 15.1(24B83)
AC 28 | M3 MAX | MAC OS 15
BIMcloud | Xeon Gold 6142 x 2 | WIN 11 PRO for Workstation
21 REPLIES 21
Thank you Kornél.
Jared Banks, AIA
Shoegnome Architects
weeez
Hi all,
Just upgraded EDU version. I have two macs - mini M1 2021 and MBP 16” M1 Max 2022 all with the latest macOS 15. My situation is that macmini still having this kind of bugs since the latest AC27 then update to 28 and Hotfix 2 afterward. But on the otherside I am happy my MBP with no issue until present. Probably new hotfix 3 will get rid the bugs.
Setup info provided by author
