2006-01-11 03:23 PM
2006-03-17 07:12 PM
Broker wrote:While my first thought was "then why are you bothering if you do not have time to learn," this made me curious just how hard it is, not to learn this skill, but to find it.
I think perhaps you underestimate or make incorrect assumptions. Surely with most users such as myself for example have been using something else for a long time (Autocad and 3D Max). The time taken to use a 'new' program out of the box is not available to all of us. I can draw a complete project in less time than it would take to even become familiar with Archicad. Sketchup is cool enough but not for mainstream work. Perhaps you should try ADT, we can give you lessons for FREE, without bias. Chill man, po-dobre da prekavash poveche vreme za semisestvo vi e ne da oplakvash sus gulposti samo da furli vremeto ot men e drugite.
Priyatna vecher:-)
2006-03-19 04:41 AM
Broker wrote:No, man.
2006-03-19 04:49 AM
2006-03-19 09:07 AM
Dwight wrote:You mean like a single click (or menu selection) to switch between OpenGL shading and internal engine hidden line views?
Right now, for instance, I'm testing a piece of software that has a control for the size and orientation of a dialog box.
There's a wide or high choice.
There's a top-on-the-side or top-on-the-top choice.
Ends up being four alternatives (2x2)
That's four lines of information.
Trouble is, you have to change each parameter separately and re-open the pull down a second time...
he didn't make those four lines of information say:
wide and top
wide and side
high and top
high and side
where just one command could do everything at once in the same four lines.
Idiot.
2006-03-19 03:42 PM
2006-03-19 05:41 PM
Dwight wrote:Graphisoft even agrees!:
I just saying that the interface decisions of designers aren't always correct: an extra click is an extra click.
2006-03-19 05:54 PM
2006-03-19 09:55 PM
Matthew wrote:I have not done this with the Toolbar, but I have set the Alt+` to be the Switch to Internal Engine. The WE allowed for a Shortcut key to Switch to the Internal 3D Engine but not to the OpenGL????
As I recall this was possible in AC7 but for some reason got "improved" in AC8.
If I am missing something? If there is a way to set up a toolbar to accomplish this please let me know.
2006-03-19 10:07 PM
Jay wrote:Thanks, I saw this too (about the lack of an OpenGL switch). Even with that it would still be a two step process. I still just open the settings dialog and change both settings there. The toolbar might be an improvement if all the options were available.
I have not done this with the Toolbar, but I have set the Alt+~ to be the Switch to Internal Engine. The WE allowed for a Shortcut key to Switch to the Internal 3D Engine but not to the OpenGL????
