2 weeks ago
I have upgraded to macOS Sequoia (15) and will post my finding of using AC27 and 28 Tech Preview here.
Operating system used: Mac Apple Silicon 15.0 Sequoia
2 weeks ago
I have come across an issue where it is not possible to select a page size under print settings for a specific printer. Only 'Any Printer' is displayed even though printers are installed. I have reported this to support. It affects both Archicad 27 and 28.
2 weeks ago
When launching Archicad 28 Tech Preview for the first time after upgrading to Sequoia I had to sign in to Archicad again with my email and serial number so make sure you have the serial number to hand when upgrading. I assume this wouldn't affect the official release.
2 weeks ago
Just a quick comment - the Technology Preview is running on cloud license only and does not require any serial number. I assume you tested Beta with a CodeMeter license and that's why you have a serial number.
Noémi Balogh
Community Expert, Admin
2 weeks ago
Hi @Noemi Balogh ,
That could be the issue, although I completely uninstalled the Beta version and installed the Tech Preview and the update so not sure why the tech preview version has requested the serial number.
2 weeks ago
Same issue - in Page Setup on MS Word, Apple Pages, Adobe Acrobat, under Page Setup only 'Any Printer' is now selectable since the Sequoia 'upgrade. If I chose Print however, both my printers are listed and are accessible.
2 weeks ago
Hi @Derek Williams,
That’s interesting to read. I don’t get that issue in Preview. I haven’t checked other apps yet.
2 weeks ago
Hi @Lee Hankins,
Only some apps have the Page Setup dialog, and from what I just checked, Preview is not one of them. Are you sure you didn't check the Print dialog (which works fine in Archicad too)?
Oleksandra Vakariuk
Technical Support EngineerFriday - last edited Friday
same issue here after installing macOS 15.0 Sequoia. Since then -no matter which application or in system-settings- the pagesize cannot be chosen larger than A3 (i.e. from Kyocera).
But we need A2 - A0 using with the canon imageprograf as well as formerly under macOS Sonoma. Uninstalling an re-installing the printers didn´t help anyway.
Friday
It is the 'Page Setup' dialogue which doesn't allow the selection of page size other than the standard A4, A3 etc. For some reason when I click 'Reply' on your post it accepted it as a solution and I can't change that. When I click the three vertical dots and select anything from the pop-up dialogue nothing responds. This is the same if I try and edit my posts.
