2008-10-25 12:20 AM
2008-10-27 04:06 PM
Jonathan wrote:ArchiCAD can use 4 cores so that should be a better choice than dual-core, even if at a lower frequency.
Does anyone know which combination would provide best performance
and speed in AC12?
quad core at 3GHz or dual core at 3.33 GHz
and the other question would be the option of 8 GB ram @ 633 MHz Vs.
4 GB ram @ 800 MHz.
Thank you
2008-10-27 04:48 PM
laszlonagy wrote:Unless you plan to use some other app running at the same time as Archicad, like Artlantis- then more RAM memory is better. Even though 20% slower internally, it's many times faster than having the O/S paging memory out to the hard disk.
4 GB of 800 MHz RAM should be better.
2008-10-27 07:29 PM
Thomas wrote:Thanks you guys,laszlonagy wrote:Unless you plan to use some other app running at the same time as Archicad, like Artlantis- then more RAM memory is better. Even though 20% slower internally, it's many times faster than having the O/S paging memory out to the hard disk.
2008-10-27 07:45 PM
Jonathan wrote:Correct, it won't.
Thanks you guys,
Sense I wont be running two apps at the same time, sounds like the
quad core w/ 4 GB of the 800 MHz ram on 64bit vista ultimate would be
the best choice because AC won't utilize over 4GB of ram, right?
2008-10-27 08:07 PM
laszlonagy wrote:Right, and the system (windows) needs to be 64 bit in order to recognize, or allocate the 4GB to AC, even though AC is 32 bit. Do I have that correct?Jonathan wrote:Correct, it won't.
Thanks you guys,
AC is a 32-bit application, 2 on the 32nd power is 4 billion, hence the 4 GB limit.
2008-10-27 08:10 PM
laszlonagy wrote:For now.
...AC is a 32-bit application, 2 on the 32nd power is 4 billion, hence the 4 GB limit.
2008-10-27 08:15 PM
Jonathan wrote:Yes, because the 32-bit version of Windows will allow only 2 GB for any application while keeping the other 2 GB for the system.
I sure appriciate the help laszlonagy.
Thanks again
2008-10-27 08:17 PM
Thomas wrote:Yes, the eventual switch to 64-bit seems rather inevitable to me.laszlonagy wrote:For now.
2008-10-27 10:46 PM
laszlonagy wrote:So, even though its @ a slightly lower frequency than 800MHz more is better.Jonathan wrote:Yes, because the 32-bit version of Windows will allow only 2 GB for any application while keeping the other 2 GB for the system.
Thanks again
Let me correct myself a bit because Thomas is right: if you run AC under Vista 64-bit and you think AC will use 4 GB then there will not be any left for the system and some other programs you will inevitably run (mail, browser, Skype etc.) In that case 8GB sounds to be a better choice: 4 GB for AC, 4 GB for all the rest. Vista will probably need about 1 GB, plus the others.
