Installing or updating your app. Hardware/software requirements, OS specs.
Articles
Great news for Archicad users! As announced at the Archicad 26 Launch Event, we are pleased to share with you that Archicad 26 is running natively on Apple silicon. The full commercial version, with all functions of Archicad 26, was released on the 24th of November. The Appl...
  • 66324 Views
  • 12 likes
  • 0 comments
In this article, you can find a list of additional software needed for installing or running GRAPHISOFT products. When you run the installer, it will automatically install those third-party products which are not yet installed, or which are out of date. If you don't want to ...
  • 32334 Views
  • 1 likes
  • 0 comments
In order for Archicad to run optimally on the new Operating System, it must be granted Full Disk Access. Why on macOS 10.15 Catalina? Apple has taken a new approach with macOS 10.15 Catalina to tackle arising security and privacy threats. From macOS 10.15 Catalina onward, th...
  • 8416 Views
  • 0 likes
  • 0 comments
Related versions: BIMcloud Basic 2024.1 and newer This article will guide you through the BIMcloud Basic installation and configuration step by step with some additional information. Before Installing Checklist for installing BIMcloud Basic in the local area network (LAN) Ve...
  • 31240 Views
  • 2 likes
  • 0 comments
Archicad Network Installation (Install Archicad as BIM Manager) Starting with Archicad 22 the standard installer for Archicad and GRAPHISOFT Add-Ons can be deployed in unattended mode. For details please consult the Install Guide for Archicad. Archicad Silent install methods...
  • 14041 Views
  • 0 likes
  • 0 comments
WHAT IS THE GRAPHISOFT SHELL EXTENSION The Graphisoft Shell Extension is a utility which modifies your Windows shell in order to display the preview and the summary of the contents of Graphisoft related files, for example Archicad project and library part files. After instal...
  • 5940 Views
  • 0 likes
  • 0 comments
REPAIR Archicad If Archicad is already installed on your computer and you run the Archicad installer, an option is given to Repair the software. This process looks through the Archicad folder and replaces the installed components with a fresh copy from the installer. Basical...
  • 9954 Views
  • 0 likes
  • 0 comments
Silent Update installation of Archicad 20 Updates (suitable for Archicad 17, 18 and 19 too) Silent mode Update install can be achieved by running the installer from the command line with silent parameter. The correct command line can be obtained by performing the following s...
  • 7297 Views
  • 0 likes
  • 0 comments
