Stay informed. Get help. Share your knowledge.
40139members
330896posts
Graphisoft Insights
Archicad 26 Apple silicon version available
Following the previously launched Technology Preview, we are pleased to announce that the native Archicad 26 Apple silicon international (INT) version is now available for download. This release offer...
0 Comments
Performance improvements in BIMx Desktop and Mobile
We are pleased to announce the latest BIMx release: BIMx Desktop Viewer – get the latest version from our revamped download site. Now running natively on Apple silicon, with improved performance. A se...
0 Comments
Design Collaboration in AEC | An Independent Survey
How are architects, engineers, and design consultants approaching design collaboration as BIM and digital technologies evolve? Graphisoft invites you to join a study conducted by research firm Tech-Cl...
0 Comments
Hot topics
Can the object Window Splay Bay 25 have a fixed pane?
Hello. This is for Archicad 25 NA. I have used the window object Splay Bay 25 in a house model. It seems it only has options for the main (middle) pane to have some sort of opening. I cannot find a way to select "not operable". That is, have all wind...
Licence key automatic upload and download
Please make an update so that every time one exits Archicad, it automatically uploads the license key. Just like it automatically downloads it when you start the program. Currently I'm in trouble, cause I forgot my "key" on my home laptop and therefo...
Modify or delete built-in IFC Properties - IFC export
I've encountered an issue when exporting an ifc: there seems to be some properties that Archicad controls itself and are not accessible via property mapping. I cleared out all Psets from the Property mapping, and all the boxes from data conversion bu...
AlexV by Contributor
  • 29 Views
  • 2 replies
  • 0 likes
Copying Walls between stories problem.
Hi,I´m having a problem copying walls between levels. When I copy and paste a wall on to new level the paste walls becomes 2d (Lines and Fills).I can copy past on the same level with no problems or in between diferente Archicad projects, but not in t...
AGaspar by Newcomer
  • 48 Views
  • 5 replies
  • 0 likes
ACAPI command to upload Library to BIMcloud Server
Hi Guys, Wondering if there is an ACAPI command to upload a folder or LCF to a BIMcloud Library? Had a trawl through the reference guide but could only find things related to reloading libraries or adding libraries to a project. Thanks,Scott
scottjm by Enthusiast
  • 13 Views
  • 0 replies
  • 0 likes
how to 'cmakelists.txt' adapt for archicad25
hello. i only just started to develop addon. but i stuck in first phase of generating development environment. following 'getting started with Archicad add-ons' post, i used 'cmakelists.txt' on vs2019. but i think the version is defferent with .txt. ...
sh_han by Newcomer
  • 39 Views
  • 0 replies
  • 0 likes
Import 3D Model with Texture
Hello All,I have a point cloud model which I have converted to mesh with textures in .ply format. I have opened this in Blender and am trying to bring this into Archicad as model with texture. Is this possible and what is the best method of doing thi...
JP1 by Participant
  • 33 Views
  • 2 replies
  • 0 likes
Railing Tool - Calling Up Properties
is there a way to call up properties of the Railing Tool such as the Override Top Rail Surface? screenshot below are the only things that get called up in the Expression Editor in the Properties: I'm simply trying to call-up the PC1 part (with the sp...
Resolved! How to show hidden geometry in floor plan?
Hallo,In the drawing of foundation, I want to draw the thickenings of the foundation slab under the columns (with the whole geometry). For the thickenings I've used the slab tool with inclined edges (Custom Edge Settings). Is there any way to show al...
Learn BIM, Your Way.
Master Archicad and other Graphisoft solutions and get certified. Graphisoft Learn provides you with the digital resources and tools to implement efficient processes in your business and build a great career.
Get ready to be challenged and achieve great results.
Get Certified. Grow Together.
Visit Graphisoft Learn
Grow Together
