2021-07-07 05:00 AM - edited 2022-04-20 06:19 AM
This article is a part of a series titled Archicad Quick Tour.
This is a collection of sample projects designed with Archicad. They are all free to download.
This project is a residential building, featuring its interior design solutions. It is completely free to download.
To explore the virtual building without downloading, try the BIMx Web Viewer by clicking on the play button below!
Scroll down to the end of the article to learn how to explore the project and what's in the project file.
Please also read the legal notice.
This project is a commercial building, featuring its interior design solutions. It is completely free to download.
This project is a mixed-use building with commercial and residential uses which is completely free to download.
This project is a large-scale residential building which is completely free to download.
This project is a small-scale residential house which is completely free to download.
To explore the virtual building without downloading, try the BIMx Web Viewer by clicking on the play button!
This project is a mid-scale office building which is completely free to download.
These sample project files are completely free to download and represent the modeling and documentation capabilities of Archicad.
You can download an Archicad pla (Archived file) file created in the International version (INT) of Archicad and a BIMx file as well.
The contents are copyright protected. All rights reserved.
By downloading any of the files linked above you accept the terms and conditions of the End User License Agreement.
By opening this Sample Project File (“SPF”) You accept the terms of this Agreement between GRAPHISOFT SE and You or the entity, on behalf of which You obtained the sub-license right to the SPF.
The SPF is an Archicad individual project file from which any other file format can be generated (included but not limited to pdf, xls, ifc, dwg). The SPF is sublicensed to You by GRAPHISOFT SE.
You are entitled to use the SPF solely for your own use and not for any further distribution or resale. The SPF is licensed, not sold, to You and You are forbidden to sub-license, distribute, provide access to or commercialize the SPF or its any component either alone or as part of another product or service. You may NOT sell, loan, distribute, cede, rent or lease or otherwise transfer or assign the right to use the SPF, to transfer or provide access to it by network for commercial use, either in whole or in part. You are expressly forbidden to decompile, disassemble, reverse engineer, translate or reduce the SPF for any purposes whatsoever.
No part of contents contained in the SPF may be reproduced, used, distributed, or transmitted in any form or by any means without the prior written permission of the copyright owner. These restrictions include in particular the prohibition to use of any part of the contents to the design and construct of other buildings. You are fully liable and shall compensate all damages to GRAPHISOFT and to the copyright owner in case of and related to the infringements of copyright restrictions set forth herein.
If you don’t agree with the terms above, please close and remove the SPF from your computer or device.
