Let's get started!
Articles
Teamwork for EDU series: Get to Know!
Are you a student? Are you using Architectural or engineering software? Do you struggle with group work? If you answered yes to any of these questions, then this is the article for you! You probably know about Archicad, Graphisoft’s flagship product....
On-boarding Education Team.png GiovanaBenvenuto_0-1644263784302.png GiovanaBenvenuto_1-1644263889076.png GiovanaBenvenuto_2-1644264026081.png
Check for Update Previews
In this article, we talk about a new feature which has been implemented within Archicad 26. Graphisoft releases Archicad regular updates every few months and if you have enabled the check for update option while you installed the software or in the A...
Archicad Start Edition 2022
Archicad Start Edition (SE) 2022 is a professional BIM solution with critical features most smaller practices need. Read this article to learn more about its capabilities. Archicad Start Edition 2022 Compared to Archicad 25Archicad 25 new features av...
Additional Improvements in Archicad 25
Table of Content 1. Line popup shows names in alphabetical order2. Updated Surface and Fill Settings3. Edit multiple Layer Combinations at once4. MEP Label5. Track Changes, Model Compare: Structure parameter6. Object Settings: Elevation and 3D previe...
wp-content_uploads_2021_05_Screenshot-2021-05-19-at-14.37.22.png wp-content_uploads_2021_05_Screenshot-2021-05-19-at-13.22.14.png wp-content_uploads_2021_05_Screenshot-2021-05-19-at-13.50.07.png wp-content_uploads_2021_05_Screenshot-2021-05-20-at-15.53.42.png
How to Store Find & Select Criteria
Archicad’s Find & Select tool lets you easily select the exact elements you want to work with. For general information on this feature, see Find and Select Elements by Criteria in ARCHICAD Help. A less well-known feature of this Tool is the ability t...
wp-content_uploads_archicadwiki_storefindselectcriteria--01.png wp-content_uploads_archicadwiki_storefindselectcriteria--02.png wp-content_uploads_archicadwiki_storefindselectcriteria--04.png wp-content_uploads_archicadwiki_storefindselectcriteria--05.png
What is Archicad?
This article is a part of a series titled Archicad Quick Tour. Archicad is a software tool for architects working in the architecture-engineering-construction (AEC) industry for designing buildings from the conceptual phase all through to the constru...
wp-content_uploads_2021_08_AC25_Box2-scaled.jpg wp-content_uploads_2019_12_Archicad-15-icon.png wp-content_uploads_2020_06_Archicad-16-icon.jpg wp-content_uploads_2020_06_Archicad-17-icon.png
Archicad versions
Version Release Platform New Features Archicad 26 2022 macOS 12.3Windows 10 Improved Attribute Management , Search in the Navigator , Opening Tool Surface Overrides, Library Part Maker Now in All Localized Archicad Versions, Enhanced Documentation an...
Ac26 Stay focused design more.jpg wp-content_uploads_2021_08_AC25_Box2_small.jpg wp-content_uploads_2020_06_Archicad_24_Box_Render.png wp-content_uploads_2019_05_AC23_BOX_Render2_TR.png
What is BIM?
This article is a part of a series titled Archicad Quick Tour. The base of BIM (Building Information Model) is a digital 3D model of the building. It consists of walls, slabs, roofs, doors, windows and such, just like the real building. In BIM we als...
Top Contributors
