2019-12-03 09:38 PM - last edited on 2023-05-23 04:07 PM by Rubia Torres
Solved! Go to Solution.
2019-12-04 09:40 AM
2019-12-03 09:52 PM
2019-12-03 11:31 PM
Hmooslechner wrote:Hi!
Just copy an element in one story -STRG + C
Switch to the next story.
Paste it with STRG + V
If Your display was displaced in the meantime, you get a dialoge which askes you, if it should be pasted in the original position or in the middle of the current sight..
2019-12-04 02:16 AM
piper76 wrote:Yes, CTRL+C, CTRL+V on Windowws OS.
By SGTR you mean CTRL? I’m actually using a PC and maybe that’s for a Mac.
2019-12-04 02:20 AM
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2019-12-04 09:28 AM
Barry wrote:Thanks Barry, is there a way to paste the object in several stories at the same time? I’m actually working on a tower
Barry
2019-12-04 09:35 AM
2019-12-04 09:40 AM
2019-12-04 09:51 AM
Barry wrote:Thanks a lot Barry! Will try it
Although if all of your storeys are exactly the same height, you could try the 'Multiply' command in the pet palette.
Set it to 'elevate' and choose your increment/spread settings and tick the box to 'Set home storey by elevation'.
Personally I think it is just easier to move to the storey you want then paste.
2019-12-08 12:08 AM
