Can't see the contents of the Bim Component Portal in Archicad 28
suleymanyldrm
Hi everyone,
When I searched for an object in Archicad 27, it was also searching in the bim components portal and showing me the results, when I do the same search for Archicad 28, I don't get any results. Has there been a change in this feature in Archicad 28 or is there something I am missing?
Btw in both images, the search option on the bim components portal is active.
12 REPLIES 12
Your comment made me think and I just checked it again. Actually, I am getting a yellow warning icon, and when I hover my mouse over it, it says there was a connection timeout. If I go to bimcomponents.com in my web browser, the site loads in a few seconds. So, yeah, there seems to be an issue with the connection:
But, I got curious, so I started testing:
1. Tried searching from my desktop, Archicad 28, using my broadband internet connection - the error occurred.
2. Tried searching from my desktop, Archicad 27, using my broadband internet connection - the error occurred.
3. Tried searching from my desktop, Archicad 26, using my broadband internet connection - the error occurred.
On my laptop:
4. Tried searching from my laptop, Archicad 27, using my broadband internet connection - the error occurred.
and then
5. Tried searching from my laptop, Archicad 27, using the internet connection of my mobile phone - the error occurred.
So, it looks like it doesn't matter which computer I use, which Archicad version I use, and which internet connection I use, the error occurs.
That makes me think there must be something on the bimcomponents.com side of the connection that causes this issue.
Hi, same here, BimComponents inside AC is not responding. In Safari the BimComponts website loads immediately. I have a new clean install of MacOS 15.1.1. Tested on AC27,28. Firewall is off. Both programs are allowed in the Local network setup. It seems like this is really a bug in AC, maybe related to new versions of MacOs?
I am on Windows, you have the same issues on Mac, so it is not platform-specific.
