Default edges color change of an imported 3dm object
Devonha
I hope this one is clear...
I have imported 3dm object to Archicad. Although everything is fine, one thing wrong is pen color of an object of edges in 3D view. Thus, via settings it is not variable, I've also tried to vary the parameters but couldn't find a solution. These edges are colored in pink, and I'd like them to be black or to be none at all.
Architecture student Tautvydas Grigalauskas
ARCHICAD 25.0.0 INT
LAPTOP-ER287GTP • AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz • 16,0 GB
1 REPLY 1
Devonha
Solved, simply override object's pen...
ARCHICAD 25.0.0 INT
