‎2012-02-21 11:06 AM
‎2012-02-21 12:43 PM
‎2012-02-21 06:44 PM
‎2012-02-21 11:43 PM
Juha wrote:Keep in mind that turning on/off this parameter will not affect already placed instances of the object. To see the affect, you will either need to place a new instance or unhide the parameter (deselect the X in the parameter table) so that you can change the setting in already placed instances.
Also uncheck the parameter named 'Show 2d hotspots in 3d'
‎2012-10-31 05:59 AM
‎2012-11-02 03:55 AM
‎2012-11-02 07:47 AM
Eric wrote:
Re the unwanted 3D hotspots, these likely come from the scripts of the original objects that were used to create the new custom object. I think that unfortunately the only way to delete these unwanted hotspots will be to hunt them down in the 3D script, as suggested by others earlier in this thread.
Eric
‎2012-11-02 12:39 PM
‎2012-11-02 06:50 PM
!___________________________________ Hotspot Helper MODEL WIRE : CIRCLE hss*1.2 HOTSPOT hsx, 0, 0, 1001, hsy, 1+128 HOTSPOT hsx, hsy, 0, 1002, hsy, 2 HOTSPOT hsx, -1, 0, 1003, hsy, 3 HOTSPOT 0, hsy, 0, 1004, hsx, 1+128 HOTSPOT hsx, hsy, 0, 1005, hsx, 2 HOTSPOT -1, hsy, 0, 1006, hsx, 3 HOTSPOT hsx, hsy, 0, 1007, hsz, 1+128 HOTSPOT hsx, hsy, hsz, 1008, hsz, 2 HOTSPOT hsx, hsy, -1, 1009, hsz, 3 ADD hsx, hsy, 0 CIRCLE hss : MODEL SOLID LIN_ 0,-hss,0, 0,hss,0 LIN_ -hss,0,0, hss,0,0 LIN_ 0,0,0, 0,0,hsz FOR f = 1 to 4 LIN_ -hss/2,0,hsz-hss/2, hss/2, 0, hsz+hss/2 ROTz 90 NEXT f ADDz hsz DEFINE STYLE "hst" arial, hss*1000, 4, 0 SET STYLE "hst" TEXT hss*.1, 0, " x= "+str(hsx,4,3) ADDy -hss*1.2 TEXT hss*.1, 0, " y= "+str(hsy,4,3) ADDy -hss*1.2 TEXT hss*.1, 0, " z= "+str(hsz,4,3) DEL 8 !_____________________________ end Hotspot helper
‎2012-11-02 09:09 PM
Temp1 = STR(INT(hsx),1,0)+"."+STR((hsx-INT(hsx))*100000,1,0)+"000000" Temp2 = STR(INT(hsy),1,0)+"."+STR((hsy-INT(hsy))*100000,1,0)+"000000" Temp3 = STR(INT(hsz),1,0)+"."+STR((hsz-INT(hsz))*100000,1,0)+"000000" Temp4 = STRSUB(Temp1,1,8)+", "+STRSUB(Temp2,1,8)+", "+STRSUB(Temp3,1,8) IDnum = INT((hsx+.001)*500*(hsy+.001)*500+hsz*5000) Temp5= "HOTSPOT "+ Temp4+", "+STR(IDnum,1,0) PARAMETERS hst=Temp5 UI_DIALOG "HOTSPOT command to be copied" UI_INFIELD "hst", 0,40,400,40
