klsdenver
Door slab modeling challanges
Can anyone describe how to successfully insert doors from the library that will model the slab panel detail on each face of the door slab? Each time I insert a door from the library, it will only model the slab detail on 1 face, not 2.
Thank you.
4 Replies 4
Ahmed_K
Mentor
The door should be modeled lile it should look like in real world, if you have a double face design, you should be modeled on both slab sides, up and down
Also, the slab dimension should match the door panel size mentionned in the door dimensions option panel, i.e :
A 90 cm door have a 82 cm panel, so your slab is 82 cm wide.
I hope this helps you
Archicad 27
Windows 11 professional
Are you choosing door panels from the list in the library part or are you creating your own custom panels from slabs and saving them as a door leaf?
If the first option, try different panels.
I remember a post some time ago where a certain paneled door style only had the panels on one side.
Actually I found the post here ...
https://community.graphisoft.com/t5/Libraries-objects/Door-Panel-Only-Shows-on-One-Side-in-Elevation...
I think there is a problem in the script for that door panel.
If you are creating your own panel from slabs and saving as a custom door leaf, then it will be as detailed as you model it.
That may be an option you can explore to get what you want.
klsdenver
Thank you for responding. I did use a standard door panel from the library, not custom. I will experiment with other doors to see if this works.
klsdenver
Thank you for the response. The problem still remains, however it is not critical to the construction documents. Just a flaw in the 3D modeling I would like to be able to correct.
