Mike96
Lifting the limitations of Dormer Shed library
I've got a problem with the native Dormer Shed in Archicad 25 and 28. I think its maximum Shed Roof Pitch value (screenshot) is hardcoded at 35 degrees. This is highly impractical and illogical limitation, and it should be increased to something like 89 deg. Sadly, I can't edit GDL myself, so I'm hoping someone would be able and so kind to try fixing it.
I placed it as skylight but the issue is the same if placed as an object.
PS
Sorry for Polish UI but I don't think this will be a problem.
Attached test model. Should I upload PLA or is PLN enough? Anyone can also start from scratch, it's a super simple example.
Operating system used: Windows 10
ArchiCAD 25
Windows 10
2 Replies 2
Mike96
@Jaime-airc_digital,
maybe you want to take a look at it? I saw you got some experience with GDL and dormers :]
ArchiCAD 25
Windows 10
In 25+ years, I’ve never used the dormer objects vs modeling the dormers structurally/fully.  The objects are cute for demonstrating Archicad but, in my view, have no place in producing meaningful construction documents and data reporting.
