Project2
I am using the project command for my 2d display which is below. I have 2 projects because I want a fill inside the object. and the second one displays the outline. this is exactly what I want.
project2{3} 3, 270, 3 + 32, 4, 91  ! adds fill
project2 3, 270, 2 !adds outline
I now want to display this object differently one story below (a beam for example) I would like the beam to only show the outline of the object but I would like the outline be a hidden linetype not solid.
Can I do this using project command or is there a different command I should be using? I know I can just do a polygon or lines but if I tilt the beam the display will not be a rectangle.
If you can give me an example that would be great.
Thanks,
John
AC12
4 Replies 4
Only the "system" linetypes will work with project comands unfortunately ;-(
Best Regards,
Piotr
Thank you for your reply.
John
Jochen Suehlo
Try this:
	LINE_TYPE dash_line
	PROJECT2{3} 3, 270, 3 + 32, 4 ,91
	PROJECT2{3} 3, 270, 3 + 32, 8
If you use a dashed Line for "dash_line", a dashed line is shown in 2D.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Works great, Thanks for the help.
