Stick - Stretchy in 3D with 1 3D-Handle
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2013-01-22 03:15 PM
2013-01-22
03:15 PM
So it is possible to follow complex 3D-meshes to build stuctures like this:
Picture:
My problem:
If you drag over 180 degrees, the stick flips in 3D to the other side.
You can easily worrkaround by move the thing to the other endpoint and drag the other one, but it sucks.
What do i make wrong?
Code:
gosub 1 ! Einstellungen usw. gosub 100 ! Hotspots Gosub "Drehungen" !!inkl Art des Stabes end ! ------------------------------------------------------ 1: uid = 1 return 100 : !!! ========== Hotspots ein Segment ========== !!! ----- x ----- hotspot 0 , y, z, uid, x, 1+128 : uid = uid+1 ! base hotspot -1 , y, z, uid, x, 3 : uid = uid+1 ! ref hotspot x , y, z, uid, x, 2 : uid = uid+1 ! move !!! ----- y ----- hotspot x , 0, z, uid, y, 1+128 : uid = uid+1 hotspot x , -1, z, uid, y, 3 : uid = uid+1 hotspot x , y, z, uid, y, 2 : uid = uid+1 !!! ----- z ----- hotspot x , y, 0, uid, z, 1+128 : uid = uid+1 hotspot x , y, -1, uid, z, 3 : uid = uid+1 hotspot x , y, z, uid, z, 2 : uid = uid+1 return "Drehungen": h = SQR(x^2+y^2+z^2) roty 90 rotx -atn(y/x) roty -atn(z/SQR(x^2+y^2)) material Mat if ArtDesStabes = "Zylinder mit Endkugeln" gosub "Zylinder mit Endkugeln" if ArtDesStabes = "Endkugel+Endkegel+Zylinder" gosub "Endkugel+Endkegel+Zylinder" if ArtDesStabes = "quadratischer Stab mit Endkugeln" gosub "quadratischer Stab mit Endkugeln" del 3 if Endkugeln = 1 then sphere Kugeldurchmesser addx x addy y addz z sphere Kugeldurchmesser del 3 else endif return !!!!Ende Drehungen "Zylinder mit Endkugeln": Cylind h, QRadius return "Endkugel+Endkegel+Zylinder": CONE h/3, Verjuengung, QRadius, 90, 90 addz h/3 Cylind h/3, QRadius addz h/3 CONE h/3, QRadius, Verjuengung, 90, 90 del 2 return "quadratischer Stab mit Endkugeln": addx -QRadius/2 addy -QRadius/2 Block QRadius, QRadius, h del 2 return
11 REPLIES 11
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-01-27 02:35 PM
2013-01-27
02:35 PM
Thanks for the permission...
Objective seems to be a "very grown up" api-solution - which partly seems to be obsolete after the coming up of the Morph - tool in AC16. What could be the cost of such a thing?
I am not looking for ready solutions. Its a kind of hobby to solve GDL-Problems. Other people solve crossword puzzles, i like to make new objects.
And i like to tell the Archicad-programmers ideas for new versions - on the german forum.
My real profession is teacher on a technical school for practical work - bricklaying, concrete works an now in growing time - archicad for pupils from 15 to 18 years. So i have time...
And i really think Your "Flexi-Tube XYZ" object has some potential!
Today i scripted a new hotspot in it, which allows it, to drag the number of segments without the need of opening the normal dialogebox - it works well but its just a little step to the target 2. d;-)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-12-15 04:36 PM
2014-12-15
04:36 PM
I am wondering, how do I stretch angles so as not to disturb the vectors and columns?
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
