2023-09-05 11:07 AM
There is here a list of all zone parameters :
https://helpcenter.graphisoft.com/user-guide/76909/
But i am not able to find this parameter into my french archicad :
I hope to find it but where ?
My aim is to be able to get it into an ifc export.
Solved! Go to Solution.
2023-09-06 09:04 AM - edited 2023-09-06 03:03 PM
Hello Garry,
My first test had been carried out from AC22 and this property is indeed not operational. However since AC23, 24, 25 and 26. Yves was right ! Being used to performing this task with more recent versions, I had never noticed any malfunction on AC22. An old and obsolete problem !
2023-09-05 12:19 PM
I am using the USA version and I don't see it in the parameters list either. It is available in the schedules parameters and the custom properties list. I would suggest to just create a custom property or expression and map that to IFC.
2023-09-05 12:54 PM
Hello poco2013,
"It is available in the schedules parameters and the custom properties list"
I do not find it into custom properties list. Where do you find it ?
2023-09-05 12:58 PM
In the property manager -- to create a new expression
2023-09-05 01:28 PM
My question was not where can I create a new property but where is the parameter i have illustrated into my first message. It seems to be absent from french version.
2023-09-05 03:40 PM
here
2023-09-05 03:56 PM
Thank you Yves for your participation. I should point out that I had previously tested all possible surface values but none seemed to correspond. The targeted value in Yves' post results in a result of 0.00m2 whatever the zone area.
Is this operational on your side ?
2023-09-05 04:19 PM
On archicad 23 I get the right value
Try updating the zones
2023-09-06 04:28 AM
I am not sure, but has it anything to do with the relation to zones settings in the walls?
Hello Garry,
