2023-05-10 04:39 PM
I'm trying to create a custom curtain wall panel but, however, I do not see that option available under the "Save Selection As" menu. I'm working in Archicad 25 Solo. Does anyone know if that option is only available is some versions of Archicad? Or does anyone know how to make that option available in 25 Solo?
Solved! Go to Solution.
2023-05-11 01:52 PM
The command you need is No CC Subtypes.
2023-05-11 07:02 AM
Check out your work environment?
Options => Work Environment => Toolbars => All menus in alphabetical oder => Save Selection As...
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2023-05-11 01:52 PM
2023-05-11 09:09 PM
Thank you both for your feedback and advice.
What I discovered was this issue only occurred when I opened an archive file and read the objects directly from it. When I opted to extract the objects to a folder on the hard drive, the issue went away.
Thanks for the signature tip David.
2023-05-12 02:51 AM - edited 2023-05-12 02:51 AM
There is a macro folder in the library that contains macros for the 'CC" (Custom Component) types.
I guess they weren't all included in the archive library.
2023-05-12 02:52 PM
Thanks for adding your signature. I think Barry is right, the standard ArchiCAD library needs to be loaded for these commands to work.
