Vertical Louvers
HJ1
i want to make vertical louver swindow...as well as vertical louvers for cutrtain wall panel ......how can we make a vertical louvers for window and as well as for curtain wall panel?
8 REPLIES 8
Have you tried modelling the louvres as you want them, selecting them and then saving them as a library part?
Guru
I was sure I had a thread somewhere around here regarding this object but I cannot find it... It is an old version, but I sort of broke the newer one while adding GS window functions and have not gotten around to fixing it... Anyway, as long as you use the "Simplified Spacing" option, this will probably work for your window. The math for the fixed panel when that option toggle off is a bit squiff resulting in this occassionally overlapping.
Ling.
but if i make it as a library object than .....would it be adjustable...like customizing panel size and angle .....or it will be be fixed only...?
Thanks for the solution......but i am not able to open the file in my laptop...i am using archicad 26...can you guide me ...how to open it?
No they will not be adjustable.
They will re-scale in size to suit the opening size, but that may not be wanted as they wont be true size.
If you want a parametric object, you may need to look for (and possibly pay for) 3rd party objects, or create your own in GDL.
Just unzip it and add it to your loaded libraries. Ideally a folder, existing or new, that you are loading.
File => Libraries & Objects => Library Manager
cuba
Here is a simple verticale louvre for the curtainwall created with param-o.
Apple M1 Max 32 GB Ventura
AC27
SophiaTorres
Thank you so much for helping.
Spoiler
Vertical louvers for windows and curtain wall panels can be made using aluminum, wood, or composite materials. You’ll need to design a frame, choose adjustable or fixed louvers, and ensure proper spacing for airflow and shading. Extruded aluminum is popular for durability. CAD software can help with design, and fabrication shops can assist with manufacturing. Finding well-written essays online can be tough, but Academized offers a great essay for sale service, available at https://academized.com/essay-for-sale here. The essay I received was plagiarism-free, well-structured, and properly formatted. If you need a high-quality pre-written essay, this service is definitely worth trying!
Setup info provided by author
