Zones GDL Parameters
Hi!
I would like to create zone which shows information according to the name of the view. It's needed for ceiling plans. I would like to make the same zone which displays differently into different views. Default UI gives a chance to create only scale dependent stamp.
I found a fragment of the code responsible for displaying specific information.
if usedRows[orderIdx]	= ORDER_ZONE_NAME		then showGroupDisplay[ORDER_ZONE_NAME] = 1
if usedRows[orderIdx]	= ORDER_ZONE_NUMBER		then showGroupDisplay[ORDER_ZONE_NUMBER] = 1
Then, i would like make it drawing-name-dependent
So I tried to use global parameters like:
ac_drawingName
ac_drawingNumber
ac_storyName
So it could look like:
IF ac_drawingName = Ceiling Plan THEN
ENDIF
It would give a chance to call my view "Ceiling Plan" and disable name of the zone (ORDER_ZONE_NAME)
It works when I use local parameters but when I use global ones (mentioned above) says that is either
"Uninitialized variable" or "Numeric type expression required".
It's strange, because global parameter "ac_drawingName" is decribed as a String.
5 REPLIES 5
Lingwisyer
Guru
IF ac_drawingName = "Ceiling Plan" THEN
Not a variable, so it should be in quotations. Whether that is the issue is a different question...
Ling.
Use rather a switch refering to MVO regerding ceilings... than autotext value, because autotext values cannot be phrased by GDL.
Piotr
Lingwisyer
Guru
Ah, that is another thing... While ac_drawingname is not an autotext but a global variable, it is only available for Drawing Title objects. Piotr's suggestion of using MVO states is probably your best alternative.
Ling.
I don't know exactly what did you meant, saying about MVO trigger. I didn't found any global gdl parameter, so I used this method:
https://gdl.graphisoft.com/tips-and-tricks/custom-made-model-view-options-object
I added my custom Zone Stamp to Library Global Settings subtype.
Then, I created part of MVO interface and now I am trying to stick my custom parameters to it. It gives a way to make it MVO-profile-dependent. It is not really what I meant to create from the very beginning, but seems like it's going to work! (:
Thank you guys, I will put my complete solution when I finish (:
Yes, I did it, Piotr Dobrowolski helped me a lot. He gave me zone stamp which was ready to work, but I decided to make something simple on my own.
Its really simple.
1. I created myCustom.gsm file and saved it as a library global settings subtype.
2. Inside the file I made bloolean parameter bNameMVO
3. In Zone Stamp file I created next parameter bNameSwitch
4. Then I used this scheme:
success = LIBRARYGLOBAL ("MyCustom", "bNameMVO", bNameSwitch)
if success > 0 then
elsetext2 0, 0, det
    text2 0, 0, "Not available"
endif
I attached variables needed and created switch in MyCustom.gsm Interface script.
This is basic way of communicate MVO interface with library part objects. For me it was important to create zone stamp which was easy to change without scale-dependency. It works! (:
