attempt to convert DXF survey to library part
Jefferson
Greetings,
I have accomplished this before, but alas not today.
My usual procedure is to open the imported DXF/DWG survey file in ArchiCAD, toggle through the layers, decide what I want and don't want, select everything I want to include, drag a copy a 100 feet or so away, put all lines etc. one one layer, add hot spots, and then save as a new library part in the project library file. I then place the new part, delete it from the project library, resize to the accurate size and resave it. I'm done!
All simple enough for me and it usually works. I have attached a screen shot showing that when i attempt to place the object I get this error message [which if I check stop allows me to continue]and some missing lines. Further when I select it selection dots indicate that the missing lines are there.
Needless to say I am confused. I would prefer if at all possible to continue importing surveys in this manner as it is simple and efficient, for me anyway. I am not a GDL inclined operator in case someone is looking to make a convert out of me, just thought I'd get that out of the way. I would really appreciate any helpful hints.
TIA
undefined
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
3 REPLIES 3
Jefferson
here's a screen hot that one can actually see............
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
Djordje
It looks like some of the lines are not exactly joined or overlap just so; you can do a few things:
- move the stuff closer to the origin
- do a Check duplicates - usually dozens in a DXF
- check whether the lines really join at corners (use chamfer and/or Intersect from the Line extras)
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Jefferson
Thanks for replying, I had given up and gone in a different direction, actually creating a new library object through the new object method as opposed to my simplified save as method. [A mini self taught GDL lesson]And it worked first time..........
But for the sake of my education, does this mean that I need to extend the contour lines until they intersect the property boundary lines?
Literally the project origin?
can do..............
You are refereing to an action I referred to in my first question?
As I indicated I found another way to get to the dance, and in the end that's a really good thing, but I still want to understand what was hanging me up in my normal method. A problem is always minimized if you understand "what's really going on". I appreciate the help.
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
