corner windows
Hello,
I searched and couldn't find an answer to this. I apologize if I didn't look hard enough.
I am trying to place a corner window in a wall. I can get it to place, but the stupid corner function keeps turning off without much logic to it. What might I be missing here?
Thanks
12 Replies 12
just to give an example. I just changed the MATERIAL and the corner function turned off.
further things I notice:
I need to have a sill. In order to have a sill, the window must be set back, but when I set the window back, it ruins the corner window setting (meaning that awful retarded looking polygon part of the left over wall shows up).
Of course, it would have been MUCH quicker to model everything separately, but as this is a sketch for a client, I may need to change things again and again and again.
Erika Epstein
Are you making the changes in the CORNER WINDOW tool and NOT the WINDOW tool?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Yes I am using the corner window tool. I had to specifically search it out in some toolbox as it wasn't open for use.
Could you post one or more screenshots about these problems?
here they are. this is where it is "working" but the wall lengths are not correct.
the second (separate post) is where it has "turned off" but the wall lengths are now correct.
second one
You must be doing something unusual because it works for me just fine.
Are you sure you have placed the Windows using the Corner Wall Tool (available in the More group of the Toolbox)? It should place both Window of the Corner Window when you place it near the Corner.
Also, when changing parameters of one Window (including Materials), the corresponding parameters of the other should also change. The only exception to this rule is horizontal sizes as the two component Windows can be of different length.
ok.
still no idea as to why the tool doesnt work on walls that are the same length as the window?
well i will keep these things in mind.. especially selecting both when editing.
thanks.
