Project data & BIM
how to customize a pop-up info tag?
How can I edit the content of a pop-up info tag (f.ex. in 3D)? When the tracker gets over an Object, the info tag contains following data: Object, its name as in Library, Layer etc.
Is it possible for a pop-up info tag to display some user defined IFC properties instead of the original library data? How can I customize the content of an info tag?
Thank you in advance!
I don't think there is any customization capability for the Info Tag.
Tim Ball
Yes you can customise
Firstly set up a schedule of the data you want to include. You can pick anything from the standard object list to any additional properties you have created. Save the schedule
Go to the publisher and open Info Set
Click that and you can then select the schedule you just saved.
All the data included in that schedule will be available when you click the Info button inside BIMX.
I use it to include all the specification data for the builder and any hyperlinks to products.
Tim Ball
AC26, iMac
User since V5
Tim, this question is not about BIMx.
It is about the simple Info Tag that appears when you hover your cursor over an element in any ARCHICAD Viewpoint.
