out of place
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-01-23
12:28 PM
2023-05-23
04:09 PM
Rubia Torres
2019-01-23
12:28 PM
When I draw a morph object or something in front elevation view (in green marked with red arrow) it looks in place but in reality it is not.
https://yadi.sk/i/NgEalL-QYfI4tw
When I look to it in 2D or in 3D it is always out of place.
https://yadi.sk/i/_f-ZH19CJ_5Zww
Please what settings I need to do to draw in the front elevation view and in place?
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-24 01:29 AM
2019-01-24
01:29 AM
This is the way morphs work.
If you draw a morph plan in section/elevation, it will be place on the section/elevation line when viewed in plan.
Then you need to move it to the actual position you want it to be.
This is because when drawing in elevation you can not set the depth (position) as you would height in plan.
Lines and fills don't matter as they are just 2D and will only show in that section/elevation.
Morphs are 3D and will show in other views.
You could place them more accurately if you do it in the 3D window.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-24 01:29 AM
2019-01-24
01:29 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-24 01:33 AM
2019-01-24
01:33 AM
Also please don't post 'how to' questions in the 'Archicad+' section.
This is for discussions about Archicad.
Please try to post in a section that is relevant to the question you are asking.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-24 08:43 AM
2019-01-24
08:43 AM
Hi Barry and thanks!
Eman / Draftsman
