problem: morph lines not showing | waffle slab | rib + coffered + caisson | smart way to waffle slab
aryastark
valar morghulis,
i convert this object to the morph.
but i want it to appear that hidden lines as when it was an object.
there should be hidden lines in the morph.
how can we achieve this?
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
DGSketcher
Legend
I am guessing this isn't a one time project? If you are going to be repeating this process the curtain wall tool may be your new best friend. You may need to invest some time in it but it could be worth it once set up how you want it.
I have attached a module file which you can place as a Hotlink module and then embed to see what's going on. Hope it helps.
10 REPLIES 10
Hello aryastark,
Did you add this script into your object 2D script after deleting the script automatically generated by Archicad ?
Project2 3,270,2
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
Guru
As far as I know, in a Morph, you cannot. There is no control of 2D Linetypes as you just see a Projection or Cut of the said Morph. There is no Symbolic representation.
For what reason are you needing to explode the object to a morph?
Ling.
aryastark
Christophe wrote:
Hello aryastark,
Project2 3,270,2
valar morghulis Christophe Fortineau,
no, i didn't.
um, and how can i add that script into that objects 2D script? and what it that for?
Ver: AC23
Memory: 16384MB RAM
aryastark
Ling.
trying to do waffle slab with "precast double tee" object. but after placement it must be split with line and spline. due to being an object, it doesnot split flexibly, even cutting is not allowed at all.
so after it multiplied several times horizontal and vertical, the whole objects stack mass should be split at the same time. that's why it should be morph.
Ver: AC23
Memory: 16384MB RAM
... what it that for?
I guess I did not really understand your aim.
To do a "precast double tee" you should try to do beams with your own profil.
Christophe - FRANCE
aryastark
thanks, but...
Ver: AC23
Memory: 16384MB RAM
DGSketcher
Legend
I think your answer lies with a slab and form the waffle grid with complex profile beams. If you use the same material they should all merge. The next bit to fix this is to look at your Model View Options (MVO) where you can control the appearance of the beams below the slab. You can also hide the blue axis line highlighted in your image in the MVO settings.
aryastark
thanks, i can't understand how can we create waffle slab with complex profile beams.
because waffle rib slab is not constant with it's section.
complex profile creates from section but waffle slab has voids and occupancies while going along the z axis.
so we can not draw it from section(with complex profile).
archicad team should make waffle tool indeed like this-> http://www.kilobim.com/laje-nervurada-archicad/
look at this man-> https://archicad-talk.graphisoft.com/viewtopic.php?t=50042
look his devious and indirect and tiring and funny and joking and boring and fixed and unchangeable way to do waffle slab.
He is struggling, he is in pain.
i will not do this with that excessively long methods. it is laborious.
for 2 days i couldn't find single smart way to build waffle slab.
there should be something. something...
i will find it, and share with you. stay on hold...
ps: these methods are garbage too. -> https://archicad-talk.graphisoft.com/viewtopic.php?p=156747#p156747
Ver: AC23
Memory: 16384MB RAM
DGSketcher
Legend
