script for differen linetypes according to each floor/floor
Hey guys
i was looking around but couldn't find it the solution so were goes
is there any script code to have an object (made only w 2d elements) to have different linetype (changeable) from the homestory to the floors below and above?
thanks
Luis
1 REPLY 1
David Maudlin
Luis:
You can use the global variable: GLOB_CH_STORY_DIST: relative position of the current story to the home story.
So by checking the current story relative to the home story of the object (number of stories above or below), you can script which line type to use.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
