Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Adding new employee to license pool?
Brad Norris
I have a new employee and trying to give him access to an available key. Under Graphisoft accounts I try to add him as a company member by inviting him using his email.  I get an error message saying he is already a member of another company account.  He has purged everything  he is aware of.  What else we do?
6 REPLIES 6
leo_
Brad,  I am having the same problem, were you able to figure this out??
Thanks in advance!
I assume that the other company will have to remove that user from their company list.
You should then be able to add them to your company list.
Otherwise that person should still be able to use one of the other companies licenses.
MinhNguyen
The person who owns the Graphisoft ID can always leave the current company. After signing in, navigate to Company details, there should be a button for "Leave Company"
Then, the Admin of the new company can invite this person to join the new company,
BIM Manager
DKO Architecture - HCMC
Lingwisyer
Guru
Out of curiosity, if you were to say work part time at two companies, would you need to create two accounts?
MinhNguyen
Exactly. One GraphisoftID can only be part of one company at a time.
BIM Manager
But only if you want to borrow a license from each company.
There is really nothing stopping you from borrowing a license from company 1 and the working on a job from company 2.
Archicad doesn't care where the license comes from.
And you would have to remember to sign out of Archicad and sign in with the appropriate ID each time you swap companies, otherwise it will just continue using the same license anyway.
