Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Connect Graphisoft ID with Archicad EDUCATIONAL License
ZEYNEP KAYA
Hello, I was trying to download Enscape. And it said ''We noticed that your GSID hasn’t been connected with an Archicad license yet. Before getting your Forward/SSA promotional Enscape offer, please follow these steps:''
But I can not follow the steps because of the first step: ''1. Open Archicad, and in the Help > License Information dialog, click on the Connect Graphisoft ID with License button.'' I CAN NOT the key is locked. I don't know how to fix and explain,
so I add photos here.
Does anyone know how to unlock this with Educational version of Archicad.
Please any answer, it is urgent...
Thanks.
Operating system used: Windows 10
Eduardo Rolon
AFAIK SSA/Forward is not available for students so you will not be able to add that particular Enscape offer to your ID.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Have you signed in Archicad with your Graphisoft ID?
Go to the HELP menu and choose 'Sign in' if you haven't.
Eduardo Rolon
AC28 US/INT -> AC08
another Moderator
Joe Logiudice
Graphisoft Moderator
Hi, to get the escape license you have to register on their site. It is not possible to connect the Archicad Edu license to obtain the Enscape one
Giovanni Logiudice
Educational Community Expert, Moderator
Certified GRAPHISOFT ARCHICAD BIM Manager
Setup info provided by author
