Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Need help with renewing educational license
Anhvo
Dear Graphisoft Community,
I have applied for another year and successfully renewed my Archicad 27 Educational License. I can see that only the license for the International Version has been updated and it shows the date until Jan 2025. I have activated with no problem. However, the German Version still does not give me a new serial number to activate. I have tried to redownload as well as make it my favorite version as suggested but it still does not work and the date is still showing 'Gültig bis: 16.02.2024'.
I am looking forward to receiving your support.
Thank you
KA
2 ACCEPTED SOLUTIONS
Joe Logiudice
Graphisoft Alumni
Graphisoft Alumni
Hi, I checked your account.
Your license has been approved, and now you can use Archicad 27 German.
You can find your serial number on your profile after logging in to your Myarchicad account.
Regards
Giovanni Logiudice
Educational Community Expert, Moderator
Certified GRAPHISOFT ARCHICAD BIM Manager
Noemi Balogh
@Pepita7312 your license for Archicad 26 Polish version is granted.
For everyone else: we check the license request usually every 24-48 hours on workdays. We recommend you keep checking your mailboxes, including spam folders, and also your profile in MyArchicad. Also, if you have questions regarding the process, check this out: Educational License: Step-by-step
Noémi Balogh
Community Expert, Admin
8 REPLIES 8
Joe Logiudice
Graphisoft Alumni
Graphisoft Alumni
Regards
Giovanni Logiudice
Anhvo
Hi Joe,
Yes, the license has been updated, it works just fine now.
Thank you so much for your support!!!
Regards,
KA
Zdobywca
I have exactly the same problem. After applying for next year it only renewed International Version.
My Polish License expired 27.03.2025.
Best regards,
Hi , I'm having difficulty renewing my education license, the 1 year renewal won't show up on my graphisoft account , I've been trying for 2 weeks now and I have no idea why its not appearing.
Thank you.
Noemi Balogh
Hi @Zdobywca and @Martina Lleshi,
Please check your accounts, both of you should have a valid EDU license by now.
Kind regards,
Noémi
Noémi Balogh
Thank you so so much!
Pepita7312
Hello! I have the exact same issue. My licence has been extended for another year (2026) but only for the international version. My preferred version is the Polish one.
Looking forward for any information,
Thank you!
Noemi Balogh
Noémi Balogh
Setup info provided by author
