AC26 critical bug - Publisher DWG "Merge to one DWG or DXF file" crash (video) - Fixed in AC26 5002
Hello Beta Testers,
Does Graphisoft developers knows about critical bug in AC26 "Merge to one DWG or DXF file" in Publisher ? And does anything being done about it ? This bug can be replicated in any AC26 file.
1. Open any file in Archicad 26;
2. Go to Publisher and choose files to be exported as DWG ir DXF;
3. Press "Merge to one DWG or DWG file" function;
4. Save or SEND/RECIEVE project;
5. Close project and try to open it again, file will be damaged.
Video link below showing this bug:
https://youtu.be/dSIRcYUbQ7o
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v26 INT / NOR (5002)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
29 REPLIES 29
You should be able to contact GS Hungary in that case. If you have an active license for the latest version I am sure the developers over at HQ would be able to assist if there is no local support. Do you obtain AC from a reseller? Do they offer a support package?
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 5003
macOS Ventura (13.5.2)
Slight change in which this has now been approved for Update 3.
Brilliant, nice one. Hopefully that is just around the corner. Thanks for your help.
Lee Hankins
Hello Mr @Mscott ,
Would be very helpful from Your side if you could write down known bugs, maybe in this place. So we will not struggle so much and look for same things that are already known. Thank You.
Frillex
Is there any workaround which is not based on Miki's video?
For us at least this bug is making Archicad a real stomach ache..
Would be a good idea to just realise the update pronto!
Thanks
Felix
AC 26, OS MONTEREY
Dear @Frillex ,
This is a easy step, It cant be any easier that this. It is ultra easy!!!!
Here are the steps:
1. Go to show organiser in navigation
2. Create (or not if you have already everything organized) new Publisher set
3. Inside new publisher set (or exiting) create new folder with a name (ONE DWG - or name it as you wish) and put all files inside it.
4. Click on all files inside new folder and change them to DWG files.
5. Click on folder that you have created and at bottom of window click Merge to one DWG file.
6. Publish.
Also I provided a video tutorial, this took me less than 1 minute to finish all steps (see attached video file)
Also I really don't understand why don't people who answer and solve issues don't upload video, of how they do it, it is much easier than writing and loosing time on writing steps.
'This is actually a known bug in AC26, DEF-10919. The fix is already done and will be released with AC26 Update 4. Until then, please avoid using this option'.
Till today we are in update 2, waiting for update 3.....
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 25-26. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
There has been an update from GS since further up this post that they are fixing it in the next update, update 3.
Lee Hankins
Thanks Miki,
I'll try tomorrow, i misunderstood the video tutorial. I though the "one DWG" was a custom translator 😛 Sorry.
Thanks for the help, I do like ultra easy stuff! 😉
/Felix
AC 26, OS MONTEREY
I know, I read the post. But as Botonis are trying to say; we don't need the already fixed problem in an update soon, we need it now 🙂
/Felix
AC 26, OS MONTEREY
