yesterday - last edited yesterday
AC 27 2D symbol baffingly wtfs when turning tread finish on. Happens on both this stair and some other one with similar settings.
Solved! Go to Solution.
4 hours ago
Check the line types used in the 2D view.
Looks like it is using a symbol line rather than solid or dashed.
It could be the line type for the tread, riser, tread accessory, etc.
5 hours ago
At 00:08, the Floor Plan symbol becomes very weird. What are all those lines? Is that a display error?
Are you using the default Archicad Tread from the library or is it a custom Tread?
4 hours ago
3 hours ago - last edited 3 hours ago
It was that. A funky line type in Tread > 2D Representation > Hidden Parts. Thanks very much.
