2023-07-11 05:20 PM - last edited Monday by Laszlo Nagy
For a project need to make a pocket door with an arched hole top ( like the one in the screenshot).
Of course there are no standard Archicad solutions, at least in the library we are using in the office ( Archicad 25 INT ).
Does anyone have an idea of how this could be done. It would be better if the element were a door and not an object.
Solved! Go to Solution.
2023-07-12 05:37 PM - last edited on 2023-07-13 03:27 AM by Barry Kelly
Use 3 slabs:
1/ Door
2/ Opening (with element Id Wallhol)
3/ Rectangle space for the door in the wall (with element id Wallniche).
Select all 3 and save is as a door (File/library and objects/save selection as/ door)
Place it in the wall.
Use projected with overhead for 2d display.
2023-07-12 04:05 PM
Empty arched opening in the actual wall and a 2nd 0 mm thickness wall to host the sliding door (which will be rectangular anyway).
Use 3 slabs:
1/ Door
a week ago
I wish archicad can update library with these items @archicad instead of us modeling these over and over
a week ago
AC has always been able to do this, but you need to learn GDL.
if you only need a quick solution, this is the standard workaround.
another Moderator
