Archicad 15 - windows and doors not sowing on plan-
Dear Graphisoft, i have bben using archicad 15, and when i put doors on the plans they do not show and windows, i have checked the model view, its all on , and when change the wall settings to symbolic the doors appear but with a green layer around it which i cannot seem to remove, in order for me to print out my plans the way i want them , please help this urgent for my work
5 REPLIES 5
Graphisoft probably won't answer, but one of us will. 😉
The first issue is probably because your Floor Plan Cut Plane (FCPC) is not set to cut through the windows/doors which were set to projected/overhead.
Setting the windows/doors parameter to display as Symbolic is one way to fix that if the FPCP cannot do what you need, or you do not want to use the FPCP. Same with the walls: Symbolic (not available for profiled walls).
The mysterious green must be that you have "Show Minimal Space" checked in the Library panel of the Model View Options ... and your fill and pens settings are set to produce a green box. (The attached screenshot shows the checkbox. The fill/pen shown there are pretty ugly too - I've never used/changed this option.) Just clear the checkmark and re-define your Model View Option.
If this doesn't address what you are seeing, please post a screenshot.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
dear mr Karl Ottenstein,
i have the exact same problem and all i have to do is hide the minimal space but i'm having a hard time findin out how.i can't seem to find the box of which u have shared a picture in this post...how can i access "OPTIONS FOR GDL OBJECTS(ARCHICAD LIBRARY 15)"?
This is a collapsable panel near the bottom of the Model View Options dialog.
thank you very much
THANK YOU very much for your explanation on how to solve this issue; I managed, also in Archicad 16, to remove the 'green field' around the object.
Good support!
Best,
Ruben
