2010-02-10 03:03 PM - last edited on 2023-05-23 02:58 PM by Rubia Torres
2010-02-10 05:14 PM
2010-02-10 05:43 PM
Erika wrote:
If they have different profiles, how are you expecting them to meet?
If the sloped one dies into the back of the horizontal one, then stretch your sloped one just to the back of the horizontal one.
Or vice versa.
2010-02-10 08:25 PM
rob2218 wrote:And I think you'll find a builder would use the same profile for both, leaving a small void above the horizontal trim. Some cutting / filling (or extending) is going to be necessary as they will never mitre correctly anyway.
Not really sure I understand your comment?
Of course they are going to have different profiles. One profile resides in the area under the overhang where the roof edge is flat (horizontal at 0 degrees) to the ground. that's the one that is sloping.
The other molding profile has a profile shape that is contingent upon how the roof overhang causes the top of the profile shape to be at an angle.....therefore, i reiterate once more...."of course they will have different profiles"....
I could, perhaps, as you suggest, make them the "same" profile and allow the one that has the angled top to be 'not right' in it's appearance...but then what would be the purpose of drawing a profile that is not correct if only for the sake of making them meet at the corners?
keep in mind that one beam with a custom profile is sloping upward at an angle (the one with the flat top) while the other beam profile is completely horizontal.
I'm sure Graphisoft must have come across this situation before. it's a common, VERY COMMON, design feature in many designes....to have a molding outside of the exterior wall right under the roof overhang traveling all along the perimeter of the house.....
2010-02-10 09:40 PM
2010-02-12 01:08 AM
