scottybaustralia1990
Cant delete image for missing texture
Hi All,
In Archicad25 you could go into surfaces and remove the associated image missing to a certain texture but now in Archicad26 this delete option is greyed out?
Marc H
Hi Scotty,
You manage the texture image files with the small upper right icons.  You can add or delete there. (Air Space does not have a texture associated, hence it's typically blank.)
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Try adding any other texture and then delete it.
