2005-03-24 11:58 PM
2005-03-25 01:30 AM
2005-03-25 04:44 AM
TDabney wrote:Tom,
...I typically ghost walls etc... underneath and show framing members and notes darker - see attached. EVERYONE does it differently!
Tom
2005-03-25 06:12 AM
Dan wrote:I agree, please show.TDabney wrote:we can all benefit from seeing more great examples like this!
Tom
Thanks,
Dan K
2005-03-25 07:24 AM
2005-03-25 02:42 PM
2005-03-25 03:01 PM
2005-03-25 05:22 PM
2005-03-25 05:37 PM
Rick wrote:
One other thing that maybe useful. There is an object in the truss library called "JOIST Beam" (I guess they wanted to emphasize JOIST... I am not shouting:). I use it. I ID them to the stock lumber size and it makes for a good framing take off. To do it accurately you need to do it like it is actually built, not exactly like the typical framing plan. First place band joist (I id them all 2x10x16 as an example). Then place and multiply for an area. Then I go off to the side (so I can eliminate it in plotmaker), and place a few extra for blocking and header material. If you have a short span that would actually have 2 - 8's cut from one 16' board, then select half of them and delete the ID. Combined with proper displaying and layering (as in other comments) it can be a very quick framing and material list.
I don't change anything in plotmaker, except adjust the box size to cut out the header material and blocking. I set the display for the framing quickviews to "no fills" for the walls, and place a hatched fill over the bearing walls. I actually use a green pen for PT joist and a brown pen for the rest... they prints 2 shades of grey and look great in pdf. You never know when color will be common in printing:)
2005-03-25 06:22 PM
