2008-02-13 03:06 AM - last edited on 2023-05-30 01:44 PM by Rubia Torres
2008-02-13 03:19 AM
2008-02-13 07:33 AM
TomWaltz wrote:I don't think so... When CLONING is chosen, there is no opportunity to choose LAYOUTS as an item to clone.
You already can (it's the huge "Add Shortcut" button in the Organizer)
2008-02-13 08:49 AM
vfrontiers wrote:No need for cloning (as you say you can't clone layouts anyway).TomWaltz wrote:I don't think so... When CLONING is chosen, there is no opportunity to choose LAYOUTS as an item to clone.
2008-02-13 02:15 PM
vfrontiers wrote:You think incorrectly then. It's been possible since Archicad 10 (maybe even in Plotmaker?), It's just called "Shortcut" instead of "Cloning".TomWaltz wrote:I don't think so... When CLONING is chosen, there is no opportunity to choose LAYOUTS as an item to clone.
2008-02-13 02:19 PM
2008-02-13 06:14 PM
TomWaltz wrote:Been using it at least since 10 and lovin' it.
2008-02-13 06:26 PM
TomWaltz wrote:Well butter me up and call me stupid. Usually this crap is hidden behind that little "mystery" arrow in the dialog boxes... But that button is HUGE... How did I miss that?vfrontiers wrote:You think incorrectly then. It's been possible since Archicad 10 (maybe even in Plotmaker?), It's just called "Shortcut" instead of "Cloning".TomWaltz wrote:I don't think so... When CLONING is chosen, there is no opportunity to choose LAYOUTS as an item to clone.
Open up the Organizer with the Layouts on the left and Publisher on the right. Select either the name of the layout book at the top or any subset on the left. You'll see a huge button to create shortcuts at the bottom of the left column. Click that and it creates a "clone" in the Publisher Set.
2008-02-13 07:08 PM
2008-02-14 01:44 AM
Barry wrote:Well... To clone a layout, just Option-Drag (Click - Hold - Press Alt/Option key - Drag) it in the Navigator or Organizer. Clones nicely, I think, with content 'n all. At least it works here!
No need for cloning (as you say you can't clone layouts anyway)..
