‎2008-09-09
02:57 PM
‎2023-05-23
03:08 PM
Rubia Torres
‎2008-09-09 08:01 PM
femi wrote:Using a composite allows you to represent any number and size of skins all contained in a single linear structure. Correctly setting the skin priorities will help joining walls automatically give correct junctions.
What is the advantage or otherwise of using a composite structure/material, instead of using the simple vectorial/symbol hatching...
‎2008-09-09 08:20 PM
‎2008-09-09 09:21 PM
Tom wrote:Hi Tom,
Are you referring to the fact that composites don't show their different materials in section or in details. I seem to have that problem as well, but not with all composites. Mostly with composites that I create; and I can't figure out what I'm doing wrong. I'm sure it's human error, wish I knew what it was.
‎2008-09-09 09:57 PM
‎2008-09-09 10:08 PM
‎2008-09-09 10:22 PM
‎2008-09-09 10:48 PM
Tom wrote:if they are the same fill, won't they 'heal' in section model views?
All three skins are now empty fill. Don't want any fills to show up, just the lines. Am assuming they should show up even with empty fill; if no fill, vectorial hatch on or off should not be an issue, right?
‎2008-09-09 10:58 PM
‎2008-09-09 11:01 PM
