Kikoria
Connecting sloped beams to horizontal beams
Hi there. I have a trouble with connecting the sloped beam to the horizontal one. This is how it looks like:
I've always had this type of trouble. I get the point that one profile is sloped and the second one is horizontal, so they can't match exactly. Bu what you do in this type of cases?
Kind regards,
Tamaz Kikoria
Architect
Technical Examination and Design Department
GEORGIAN WATER & POWER
2 Solutions
DGSketcher
Legend
Put a 90 degree flat return on the top beam and connect the sloping beam to it.
Go to post
Yes.
You always need to turn the corner on the same plane, otherwise it is impossible to mitre the profiles (properly).
The builders will have exactly the same problem on site.
I am not sure what the technical term is, but I call it a transition zone.
Here is a post I made some time ago using a profile in the railing tool.
It shows the transition of the profile around the corner.
https://community.graphisoft.com/t5/Modeling/Profile-to-follow-slope-of-roof/m-p/219961/highlight/tr...
Go to post
5 Replies 5
Gordana Radonic
Community Manager
Community Manager
Hi @Kikoria
Are you using complex profiles with the beams in the example?
Regards,
Gordana Radonić
Community Manager
DGSketcher
Legend
Kikoria
Yes, I am. But this case happens in simple profiles too.
Kind regards,
Tamaz Kikoria
Architect
Kikoria
Do you mean something like that?
Kind regards,
Tamaz Kikoria
Architect
Yes.
