2007-01-31
06:52 PM
2023-05-26
03:01 PM
Rubia Torres
2007-02-22 09:55 AM
2007-02-23 02:21 PM
Akos wrote:You can try switching the corner window function off, transferring parameters, then switching the corner window option back on? Just a gues ... long time since I have last used a corner window!
I know... but I though there might be a trick to do this since they use same window files with same parameters.
2007-02-23 03:40 PM
M wrote:You might consider building a Favorite file with your "popular" windows per-set. Same with doors. This has made my day much better after taking the time to first do it. It's down hill after that:)
I have set up a window with all of the right frame and sash dims, materials, pens, etc. I want to copy these atributes to another window but using the eyedropper and syringe changes the new window to an exact copy of the other window. Is there a way to copy all parameters except size and type?
Thanks, Matt
