2017-03-19
02:13 PM
- last edited on
2023-05-24
08:32 AM
by
Rubia Torres
Solved! Go to Solution.
2017-03-20 03:12 PM
2017-03-20 03:12 PM
2017-03-20 06:59 PM
2017-03-21 07:56 AM
2018-05-23 11:55 PM
2020-04-30 01:08 PM
mikas wrote:I've created a custom panel object using slab tool with thikness 0.01m. When I then use it with the curtrain tool, it goes automatically to a minimum thickness of 0.032m!
Just like Laszlo described. Model the panel with suitable elements, select the elements, and save as curtain wall panel. The panel will be selectable in curtain wall settings, or in 3D then modify-mode is on. Panel will stretch to the size of a given frame (see pic). You might have to make a few panels to achieve what you want.
In the pic I made 9 roofs with small gaps between them. Custom panel is the one which lies horizontal in front of the curtain wall.
2020-05-04 02:43 PM
kkouroun wrote:Hi,
Is it possible to have a curtain wall with really thin custom panels?
Thank you in advance.
(I use Archicad 20)
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
