Door Reveal on "both" sides? How to do?
rob2218
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
6 REPLIES 6
this could be part of a solution
rob2218
HELLO STEVE!
HAPPY NEW YEAR MY FRIEND!
I was hoping you wouldn't say that.
it's a 3-dimensional reveal so the top of the door header needs the reveal also.
I was playing around with it. Seem I had to use a "door" 'AND' an "opening" object to create the desired effect.
Seems there is no door reveal or window reveal with the chamfer on both sides......bummer
also, it appears the "reveal" lines (ends of where it cuts the doors in plan) leave this heavy line graphics............hubboy. it can't be simple now can it.
i>u
Edgewater, FL!
SOFTWARE VERSION:
I like the three wall method.
https://www.screencast.com/t/QzLswz0Mo
rob2218
"Ingenius" Steve....very nice work-around
thanks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
I like it because it works ok in 2d if you set the center wall lines the same color as the fill, and the the splayed part is easy to modify. For example if you wanted the splayed part to be a foot wider than the door or something.
rob2218
awesome!
i>u
Edgewater, FL!
SOFTWARE VERSION:
